Wall Tool Questions
PostPosted: Tue Oct 09, 2018 5:33 am
by ESSUuser
Hi All,
I am from the USA and have been using Sketchup for quite sometime doing framing details and the like manually. I am currently a retired Construction Superintendent mainly having worked on Multi-family Residential projects. Many times over the years, I've used Sketchup to graphically workout construction details that were either missing or vague. You know Architects, they see the finished project, but have no idea how to get there.
A number of years ago, I used a product called Cadsoft Build to redraw the Architect's Plans in 3D. Build was a completely customizable parametric database Cad program. I was able to create every wall type, window door, etc. and ended up with not only a finished rendering, but a complete takeoff of purchased lumber by preferred lengths and cutlist complete with waste. That saved around a 100K in lumber cost. In recent years I've used mostly Sketchup. I've been asked to come out of retirement to run one more project, which I'm considering if I can complete a lumber takeoff, schedule, etc. before project startup. This is why I was so interested in PlusSpec, it's about the closest thing to Build I've seen since working in Sketchup, especially with the planned updates (mainly custom wall types). Ok, enough background, now my questions.
Australian framing methods are similar to USA methods but enough that understanding the wall tool dialog has been challenging, much trial and error.
#1 - I have looked for a detailed explanation of what each of the layers in the wall represent. For instance, I wanted to construct a 2x6 Structural Stud wall @16" oc, 5/8" Drywall interior, 1/2" OSB sheathing exterior, R-21 Fiberglass Batt insulation in the wall cavities, Tyvec Housewrap and Vinyl Siding cladding. Using the following setup, I end up with the Tyvek graphic glued to the backside of the Vinyl (visible only from the cavity side of the wall. The insulation graphic encompasses the entire wall structure (inside and out). The default choices in any of the layers don't give me a clear understanding of which layer to use for which element of the wall. Does anyone know of a source for this information?
Wall Tool.jpg (116.64 KiB) Viewed 2678 times
#2 - I saw a post that explained how to extrude the edge of sheathing above and below the wall, but have not found any information on how to extrude sheathing horizontally (to cover gaps, create overlapped corners, etc.) Can this be done? SEE EXAMPLE:
Extrude Sheathing Sample.jpg (65.36 KiB) Viewed 2678 times
Since I'm new to this forum, I tried posting on the new user category, but could not post images, so pardon me for all of the boring dialog at the beginning of this post.
Thanks in advance for your help.
ESSUuser
Re: Wall Tool Questions
PostPosted: Mon Oct 15, 2018 11:23 am
by Zach
Good Day ESSUuser,
Thank you for your post. To answer your questions, I will break this response up into two parts:
1) Currently we don't have anything to help explain further about where the materials will be applied than what's in the dialog. The images on the left of each material field (Wall Tool only) show which section of the wall (the part highlighted red) the material will be applied. To help achieve your desired wall type, I would recommend the 'Lightweight Multi-Skin' wall type in the Wall Tool as it might be better suited for the wall you are trying to create, as well as it'll add a thickness to the OSB Sheathing.
2) There is no current way to extrude the ends of walls to cover gaps. At this time the only thing to do is manually edit the wall to give the correct/desired result. Please note that any manual edits to PlusSpec geometry will not be remembered if the wall is edited/redrawn.
Could you please try these suggestions and let me know how it goes for you?
Zach Lemonius
