roof window
roof window
Postby Trev » Fri May 26, 2017 10:49 am
hi guys
can we please have a roof window option like a velux window
Trev
Re: roof window
Postby Andrew » Mon May 29, 2017 11:00 am
Hi Trev, thanks for the suggestion, We can add in roof opening automation for Skylights, ideally we had a roof window company so we can add specific items that can be estimated. If you are talking with your representative, please pass on our details. The goal is to make the estimating and designing easier.
In the interim, here is a good solution Go to https://3dlibrary.rubysketch.com/entries/skydome-glass-skylight-550-x-1100 login and download a SkyDome model, there are hundreds of different variations, you can drag and drop it or download and add to your 3D model. If you want to cut a hole you can simply triple click the roof, trace the opening, hide the face and add the Skylight.
Skylight selections are many and they are free to download and will estimate in PlusSpec
Skydome Skylight Velux 3D model in roof lighting & ventilation.jpg (102.5 KiB) Viewed 1978 times
Return to Suggestions
