Roof framing tool
Roof framing tool
Postby bfc911 » Wed Jul 08, 2015 12:48 pm
It appears tht when you draw existing roof framing on an existing roof these items show up in yr BOM, There is no option under framing for existing/demo. I initially assumed if you using an existing roof the framing would be existing, there is also no manual override for this. This is a great tool but when you need to tie into existing structure it then becomes difficult to separate especially when it comes to take off.
regards
bfc911
Re: Roof framing tool
Postby Dean » Thu Jul 09, 2015 11:48 am
You are correct in saying that there is no existing/demo for roof framing. This does not mean that it is not possible.
Currently the take-off will not read anything that is locked. So when you tick the 'Existing' box in the wall tool for example, all that happens is that PlusSpec automatically locks the wall and the wall can now not be edited and it will not be picked up on the take-off. So when you have roof framing that is existing, all you have to do is right-click on the roof framing and select 'Lock'. This is the same as ticking an existing tick box.
We will implement an existing tick box for roof framing in the future.
Postby bfc911 » Fri Jul 10, 2015 12:38 pm
Tnkx for that, handy tip. I was using layers so now I only need to use layers for the demo part to control info in the take off.
bf
bfc911
Postby Dean » Mon Jul 13, 2015 11:56 am
using layers for demo is very effective. You can turn the layers off for an accurate take off of new materials.
Return to Suggestions
