Ok, thanks Neil
item 1 is to remove the head trimmer under the header/Lintel. The workaround at the moment is to type in a negative "
frame buffer top" in the frame section of the wall tool . This way you only need to delete the header trimmer instead of moving the lintel height and jamb studs. You could also save this as a vignette.
this is the workaround for doing so.
1. Go to the
wall tool2. scroll down to
Framing3. Type a negative number in "
frame buffer top" ( in your case, it would be the window/lintel clearance minus the thickness of the framing timber/wood/lumber) If using 90x45 and you may need a 20mm clearance (
depending on lintel deflection) ***** the header and window the equation would be 20mm-45mm=-25mm so type in -25mm in the "frame buffer top" section of the wall tool.
4.
click submit5. Draw all walls
6. Add joists or roofs etc. in a vignette and save it as a component in the component menu inside Sketchup
7. Delete the header trimmer
- wall framing header details for removing lintel trimmer
- Removing header trimmer from wall frame when using double header lintels.jpg (461.17 KiB) Viewed 13013 times
I know it's not ideal, but it will save you a lot of time editing frames.
FYI: We do this in Australia because we only use single lintels on smaller spans or non-loadbearing walls, and therefore the frame needs to be packed out for plasterboard (GIB/ Drywall) or external cladding. I assume you use a batten for cladding packing.
Item 2 Add extra jack/cripple studs under the sill trimmer.Yes, I agree with this one. The way it delivers is the cheapest method of building wall frames, but I would always add these studs on my jobs. The current workaround is to select the existing Jack cripple (when deleting the lintel trimmer above) and use CTRL MOVE to position the new studs.
- Note item 16 raked studs. This is there so in the advance framing takeoff raked wall studs will be labelled and measured for onsite cutting (PlusDesignBuild Only)
- Wall framing member names Australia New Zealand USA UK ireland.jpg (329.21 KiB) Viewed 13013 times
Item 3
Different size Ribbon/ Top plate. This is an unusual one. We will have to develop this one. Currently, the best workaround is to use the beam tool and click the flip plate option; yet we do have the option hidden in the masonry wall tool as a top plate, so this should not be too hard. All we need is the selection criteria.
- using the beam tool for ribbon plate sizing workaround. PlusDesignBuild PlusArchitect, Plusspec
- Ribbon plate with beam tool.jpg (198.6 KiB) Viewed 13013 times
1. choose
beam tool2. choose
beam type (note masonry wall already has a top plate option)
3. Choose the section size of material
4. Scroll down and click
Plate flip5. click
submit6. draw a plate; you have two options:
Option 1 click from one end of the frame and double click on the opposite end of the frame. This will create the plate at the length.
Option 2 draw a plate around 400 long> copy and rotate. Move all plates to the top of each wall that needs the special size ribbon plate. Select the beam and right-click "extend beams" or "mitre beams" Mitre beams will be faster as it will extend both plates at the same time.
